Durability of 1500 axles
Old Oct 25, 2010 | 03:15 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
so is the 9.25 pretty stout?
Very. The only thing that really kills them is that the pinion nuts back off. I loc-tite the crap out of them when replacing the seal. I've even put a couple tiny spot welds down before.
The 44 is also quite strong; it's the shafts that aren't. But there are upgrades available for them that make the 44 shafts stronger than a stock 60 shaft. However, I don't know that they're available for a disconnecting dodge axle. Not sure if you can install an inboard seal and eliminate the disconnect altogether, just run a normal long shaft.
I had a 9.25 and 44 under my '80 powerwagon with a 440 and NP435. They were spooled and turning 35" mudders. Only thing I ever broke were the outer shafts on the front.
Old Oct 25, 2010 | 01:41 PM
Sniperinhisname's Avatar
Sniperinhisname
Originally Posted by dhvaughan
i think its a lot of money, but they're not cheap. try minton motors just as a comparison. i think they're in KY, so you could drive up there and get them. if you did swap housings, and you're paying someone else to do the setup, you could have them built up before your swap, and have a lot less downtime.
SON, i just called minton motors and they want 1000 BUCKS for ONE AXLE and i could get two for 1200. i'll stick with the two for 1200 and they are out of a wrecked 2500 cummins so its a dana 60 and 70 right?
