95 1500 gear swap
Old Oct 25, 2010 | 12:09 PM
95BIGRED's Avatar
95BIGRED
Default 95 1500 gear swap
ok so im going up to 35's soon i already know that i wanna run 4.56, but i also wanna put a locker in the rear. can anybody shoot me a link to what i need to get. im looking for something that wont break the bank.
Old Oct 25, 2010 | 12:21 PM
95BIGRED's Avatar
95BIGRED
Also when installing a locker do i still have to buy the ring and pinion as well or is that included with the locker.
Old Oct 25, 2010 | 01:21 PM
audiomechanic's Avatar
audiomechanic
Unless you have the specialty tools to do the swap, I'd let a shop do it, boss. Rebuilding a differential looks simple because it's a simple mechanism. Truth is, performing heart surgery looks easier. Might be why a shop will charge you $250 for the gears and $800 for labor. There's a lot that goes into it.
Old Oct 25, 2010 | 01:34 PM
merc225hp's Avatar
merc225hp
Here's a link you can check out. There is no such thing as cheap when it comes to gears and lockers. If you have a friend that really knows what they are doing then you can save some bucks, but make sure they have all the right tools to do this, If they don't say thanks and take it to a shop. You probably find cheaper in the states but this will give you an idea of cost and what you will need for tools and parts.
http://www.iwerearendsonly.com/produ...SLER+9.25+REAR
Old Oct 25, 2010 | 01:41 PM
95BIGRED's Avatar
95BIGRED
i found a lockright locker for a decent price, but the question still is do i need to also purchase the ring and pinion or does the locker take care of that. and yes ive got friends that can help me with the install.
Old Oct 25, 2010 | 01:45 PM
95BIGRED's Avatar
95BIGRED
http://www.jegs.com/i/Richmond-Gear/...arentProductId
and will this work for the front? not quite sure what it meant by 69-98 chrysler w100 & w200.
Old Oct 25, 2010 | 01:57 PM
merc225hp's Avatar
merc225hp
Yes you will have to buy the r&p and a locker. The front diff is a Dana 44, I am not sure on that one but, It looks right. I was on the internet the other day and I found a site that was selling both axle's(front&back) r&p plus install kits for around $450 I'll see if I can find it again.
Old Oct 25, 2010 | 02:02 PM
merc225hp's Avatar
merc225hp
What gears are in your truck now? You will most likely need a new carrier for the front as well.
R&P Carrier Breaks: 3.73-lower, 3.92-higher
Old Oct 25, 2010 | 02:04 PM
95BIGRED's Avatar
95BIGRED
that would be great
Old Oct 25, 2010 | 02:14 PM
Sniperinhisname's Avatar
Sniperinhisname
this will be about the best cheapish gears ya got
http://completeoffroad.com/c-69615-p...-packages.html
