Installing Aftermarket Stereo.
Old Jun 5, 2005 | 10:43 PM
98Machz's Avatar
98Machz
Default Installing Aftermarket Stereo.
I have a 98 Ram sport ext cab and I just installed my stereo and now my front speakers will not work. I bought the plugs that plug right into the stock harness and hooked them all up right. I checked the stereo by hooking up a speaker to the deck and it worked fine. Any help would be appreciated.
Old Jun 5, 2005 | 11:48 PM
Tani1500's Avatar
Tani1500
Default RE: Installing Aftermarket Stereo.
that sucks, the only thing i csn think of is that maybe theres a brocken pin. or you only have the radio set for the rear speakers.
Old Jun 6, 2005 | 12:48 AM
MAGICDSSMAN's Avatar
MAGICDSSMAN
Sounds like you have the same problem I did. mine did the same thing and it was because I didn't have the amp wire hooked up. Go over all your connections and make sure the amp wire is hooked into some sort of power source.
Old Jun 7, 2005 | 01:40 AM
cableguy's Avatar
cableguy
If you have (had) the infinity system, you need to turn on the amps that are mounted on the speakers.
