what gears should i run with 38" tires???
Old Oct 28, 2010 | 10:54 PM
TRTPLAYER's Avatar
TRTPLAYER
(nobody makes 4.88 for the front- 4.56 is the deepest)..
i thought you were suppose to run the same gears in both front and rear right?
if not can i run 4.88 in rear and 4.56 in front and what will that do if i put it in 4wd? or should i just go with 4.56 front and rear?
Old Oct 28, 2010 | 11:21 PM
aim4squirrels's Avatar
aim4squirrels
Must be the same ratio or you can kiss the transfer case goodbye.
Old Oct 28, 2010 | 11:39 PM
TRTPLAYER's Avatar
TRTPLAYER
so in other words i will have to run 4.56 front and rear or upgrade to the dana 60
Old Oct 29, 2010 | 12:26 AM
Hahns5.2's Avatar
Hahns5.2
There certainly are 4.88 gears for the D44...
Old Oct 29, 2010 | 12:53 AM
redheadhunter21's Avatar
redheadhunter21
OK this from yukon's website
Regular set of 4.88's for dana 44
http://www.yukongear.com/ProductDeta...px?ProdID=3319
Thick set of 4.88's for dana 44(can be used in a 3.73 break carrier)
http://www.yukongear.com/ProductDeta...px?ProdID=3318
Old Oct 29, 2010 | 12:55 AM
merc225hp's Avatar
merc225hp
4:88 are available for both diffs so yep you can.What most are trying to say is that the dana 60 is more suited to larger tires like 38's
Available ratios for dodge 9 1/4 rear diff: 2.71, 2.79, 2.94, 3.21, 3.55, 3.90, 4.10, 4.56, and 4.88
Available ratios for Dana 44 front diff:2.72, 3.07, 3.31, 3.54, 3.73, 3.91, 4.09, 4.27, 4.56, 4.88, 5.13, 5.38,5.89
Old Oct 29, 2010 | 01:12 AM
grox's Avatar
grox
Well, I guess that I am a bit old-school with my speedo then, I am pretty sure that my 94 reads from the transmission for the speed, meaning that the gears do matter.
Old Oct 29, 2010 | 01:38 AM
dodgeram07's Avatar
dodgeram07
how long u keeping the truck?
its going to cost sum good money to put gears in the truck,,,, wouldnt be much more to put sum d60's and then you would have sum thing ,,, d44 dont like ahole alot bigger than 35's and if you break your 44 your out money twice
just say
Old Oct 29, 2010 | 11:00 AM
TRTPLAYER's Avatar
TRTPLAYER
how much would it be for a set of dana 60s?
Old Oct 29, 2010 | 11:18 AM
4HoNdaDODGE's Avatar
4HoNdaDODGE
i say upgrade to the dana60 to itll be well worth it..BUT i just wanna say my buddy runs 37s with the 44 and stock gearing and its his daily driver and pounds the crap out of it the mud like compeats in mud bogs and has never had one problem
