abs help? Does my 94 have it?
I need an inner alxle shaft r side for my truck. When i called to order one i was asked if it was rear or all wheel abs. Does any one know off hand, i am not home to look but need to get it ordered. The only thing i can remember was the brake line itself on the front hub. help please?
The 94's did not have 4 wheel ABS available but rear wheel was standard. I don't think it matters when replacing front axle shafts although non-abs may be cheaper. I do know that the abs outer stub shafts will work on a 4 wheel abs truck as I have an abs stub shaft for my '94.
A good source of axle parts is Machine Service. I purchased a brand new abs stub shaft (non abs not available) at a reasonable cost.
