96 ram?help please...
Old Nov 11, 2010 | 07:38 PM
  #21
69skylark's Avatar
69skylark
it was the damn plenum gasket.i had the dealer do it.it idles fine now but i kept hearing a running water sound behind the dash like a gurgling noise and the heater blows cold even though the truck is warmed up.
Old Nov 11, 2010 | 08:18 PM
  #22
murren's Avatar
murren
gurgling sound could be air trapped in heater core..located just behind dash on passenger side. I was told I have the same issue, but need the knowhow to bleed the air out..any help?
Old Nov 11, 2010 | 09:39 PM
  #23
dhvaughan's Avatar
dhvaughan
park with the front end elevated. remove radiator cap (don't get burned), and let it idle for a good while with thermostat open. rev it up a little to get good water pump flow. fill overflow tank to max, replace cap, that'll likely stop it. if not drive it a couple more days and it'll go away.
