2000 ram pcv valve
Old Nov 19, 2010 | 04:13 PM
marine8385's Avatar
marine8385
Default 2000 ram pcv valve
i have a 2000 dodge ram 1500 with the 5.9 can anyone tell me where the pcv valve is and would that cause it to idle rough and bog out sometimes ??? thank you
Old Nov 20, 2010 | 01:08 PM
jasonw's Avatar
jasonw
Site Moderator
It is possible, but there are several other reasons it could idle rough and bog out as well. TPS and IAC come to mind. If you look at the FAQ section or do a search of the forum, you'll find a ton of info on those little dudes.
If you want to try it, the PCV valve is really inexpensive. The PCV valve for the 2000-2001s, IIRC, is on the driver's side valve cover, towards the back. It has a short vacuum hose going from it to the intake manifold. This is one of those parts that you don't want to get from the auto parts stores, because they have a generic unit that reportedly doesn't work as well. You can get it at a Dodge dealership for about $8 (as of a few months ago). Replacement is simple... pull the old one straight up, pull off the hose. Push the hose onto the new one, push it straight down into the hole the old unit came out of.
I will move this to the 2nd gen section (1994-2001 Rams), if I missed anything, the guys there will fill in the blanks.
Old Nov 20, 2010 | 05:55 PM
UnregisteredUser's Avatar
UnregisteredUser
A handy tip: It's much easier to swap out the PCV valve if the engine is warm so the valve cover grommet is pliable.
