Ive got a jet stage 2 and its garbage. I think all it does is run a bit richer and add 3-4 mph faster on each shift. Ive heard of the venom 400 being better. I cant seem to find the alomost extinct mopar pcm. Thanks for suggestions and stats.
NO SCT on a 95, OBD-I. No Diablo at all for a second gens, unless that's a very recent development. I think your best bet is to contact B&G Chrysler and see what they can do for you. Mopar performance PCM would be the next best bet.
Thanks guys yeah its an OBD-1. Umm never heard about the B&G Ill look into that. im guessing venom's a no go. And silver dodge. Youve got 1.7 rockers. I hear unless you build your engine and have a decent cam lift it adds no extra power. Is that true or not?? Thanks again.
I looked it up and might call them about a custom flash. Ill just tell them what Ive got. Seems the best route. Thanks Zman17 and all who helped. Like I said Im brand new to this.
Not true. They add a noticable amount of power, and I highly recomment them. If you do a cam, you most likely would NOT want to do 1.7 rockers unless you take them into consideration when picking your cam profile. Most cam packages are for 1.6 rockers though.
