late shifting from 1st gear
Old Dec 1, 2010 | 12:44 PM
stugatz's Avatar
stugatz
Default late shifting from 1st gear
Hi there, New to the forum.
I have a 1999 dodge ram 2500, and it does not want to shift out of first gear, unless I let of the gas, then it will shift. I changed the fluid/filter and replaced the trans speed sensor, still no dice. It still wont shift properly. any other ideas would be great.
OH i supose I should mention that this problem occured litteraly overnight.
i t worked fine one day, then the next day poof! no shift right.
thanks.
Old Dec 1, 2010 | 03:53 PM
NTD69's Avatar
NTD69
samething happened to me dude! turned out to be gov. proablem and tcc fixed it with new tranny WTF right
Old Dec 1, 2010 | 05:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try replacing the Governor Pressure switch and Solenoid(get them from a good tranny shop), and adjust the front band properly. If that doesn't fix it, then time for a rebuild. I'm in the same boat as you right now. Front bands,servo, clutch or whatever are shot.
Old Dec 2, 2010 | 04:43 AM
stugatz's Avatar
stugatz
and that stuff can happen overnight?! ya figure a transmission MIGHT give a little warning it was about to grenade.. thanks for the input folks!
DOH! I supose I should mention its a fuel sucking V10 dodge ram...
Old Dec 2, 2010 | 11:26 AM
rideordie's Avatar
rideordie
If it is acting up by not shifting right, that would be your cue to look into the issue.
