Push-Pull Headlight Switch to Turn style?
Old Jun 11, 2005 | 01:53 PM
Two60s98's Avatar
Two60s98
Default Push-Pull Headlight Switch to Turn style?
Is it possible to switch out our push-pull style headlamp switch to a turn style one? Not sure if turn ones came on later model years, or maybe ones equipped with foglamps.
Oh yeah, where would the factory foglamp switch be mounted? Ours doesn't have any 'blanks' in the dash for one to go. Someone installed aftermarket fogs in the stock round bumper holes, but their switch is not really mounted.
Old Jun 11, 2005 | 02:01 PM
mxmancr250's Avatar
mxmancr250
Default RE: Push-Pull Headlight Switch to Turn style?
My 2001 has the factory fog lamps installed and the switch is a turn style and when you pull it out it turns on the fog lamps. BUT, your set up might be the more desireable one as I have seen several complaints on this forum with the set up that I have seems to have some problems with the fog lamp portion prone to breakage. You might be better off leaving yours the way it is and mounting your fog lamp switch somewhere better to your liking.
