Tranny Problem
recently I had to do some repairs to my wiring harness, specifically wires had become bare at the torque converter connector plug. I fixed the issue and drove the truck for a month or so. Now I am experiencing total loss of transmission in any gear after lets say a block to 3 blocks. I'm kind of puzzled due to the solid engagement after letting truck sit for 30 minutes.
I first noticed the shift acting a little funny a day prior. It wasn't wanting to shift correctly while in drive, hesitating to shift. Then while I was driving it lost power. Engine runs fine, but no power transfer through driveline. My truck is a 1997 ram ext. cab, 5.9 gas automatic with OD.
I also noticed there is a whine coming from what I expect to be the torque converter. Is there something I need to look for besides the torque converter or has my tranny decided to give up?
may have given up.....but first, hows your fluid? you MUST check in while running in neutral....park will NOT give you an accurate reading, and you MUST put ATF+4 in (@ $5.99 a quart....at least for the kind i like.)
You can try replacing the Governor pressure switch and Solenoid. And adjust the bands if you have the proper tools and know how. In any case, drop the pan and see what it looks like in there. If it does not look good and there is alot of crap on the magnet, the Governor soleniod could very well be clogged.
