dodge runnin choppy
Old Dec 11, 2010 | 09:41 PM
ch1p~m@gnet's Avatar
ch1p~m@gnet
Default dodge runnin choppy
First off been thru here a couple times and found some good things, But now i have an issue i havent seen on here 1st i have a remanufactured dodge 5.9l with less then 10k been running good (if you overlook the obvious tranny issues) in a 99 1500 4x4 but just recently, when i start it up it runs good for about 1-2 minutes then sounds like a giant vaccuum leaks happens and it goes to poppin and sputering like its gonna die, and when i go to take off it pops like corn with now power till the rpms come up enought, So we pulled off the throttle body and cleaned it with some gumout carb cleaner put on a new gasket and reinstalled, issue still exists so went to junk yard pulled a body off a 01 that had been wrecked put it on i left the iac , map and tps sensors in the body from junk yard the dern thing still runs like crap the problem can happen anytime i could drive 100 miles and pull in to get a soda come out and its choppin away i have discovered when its struggling its suckin alot of air thru the IAC section on the throttle body i love how all the issues arise when its cold out i need to figure outs whats up with this thing so i can make it to work this winter any suggestions on what the problem could be would be very helpfull
Old Dec 12, 2010 | 07:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Try replacing the pre cat o2 sensor.
Old Dec 12, 2010 | 09:19 AM
UnregisteredUser's Avatar
UnregisteredUser
Pre-cat oxygen sensor, guarantoldja.
