99 ram no inside lights radio or low beam head light help
Old Dec 12, 2010 | 05:32 AM
99ramsport2500's Avatar
99ramsport2500
Default 99 ram no inside lights radio or low beam head light help
99 2500 sport ram 4x4 no inside lights radio or low beam head light only high beams work. it sat for a year outside and it wouldn't start cause battery was low i could play the radio then replaced battery now the radio doesn't work im not sure if the inside lights worked before i bought it..
Old Dec 12, 2010 | 08:57 AM
Ram_King's Avatar
Ram_King
there is a fuse in the fuse block on the drivers side door that has a yellow clip on it it a 10 amp fuse it morethan likely your problem. i had the same problem in my 98 last year, check it out let me know
