Something wrong with this picture
Old Dec 13, 2010 | 12:21 AM
Sheriff420's Avatar
Sheriff420
Default Something wrong with this picture
Can you guess what it is?
Old Dec 13, 2010 | 12:33 AM
offroadjosh's Avatar
offroadjosh
Crack? Bad exhaust leak?
Old Dec 13, 2010 | 12:39 AM
Sheriff420's Avatar
Sheriff420
You won!
I always wondered how long the Ebay cheapies would last and now I know. About 4 years. But that probably wouldn't have happened if the y-pipe wasn't holding pressure on them. I had to squeeze the y-pipe together to get it to fit on the headers after I installed them.
But that's nothing the Lincoln can't fix, just need to get some new bolts.
I thought that this noise I've been hearing was just the roller rockers because I didn't notice it until after I installed them and the whole time I've thought it sounded like an exhaust leak.
I finally got in there and looked the headers over to check for soot and it wasn't too hard to find that crack.
Old Dec 13, 2010 | 12:41 AM
DukesOfHazzard's Avatar
DukesOfHazzard
shoulda got gibsons or longtubes????
Old Dec 13, 2010 | 01:02 AM
Sheriff420's Avatar
Sheriff420
Nah, the plan when I got them was to patch them up when the motor blew holes in them.
Old Dec 13, 2010 | 01:04 AM
dodgeram07's Avatar
dodgeram07
mig that bitch
Old Dec 13, 2010 | 01:22 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I don't think long tubes would be the answer mine blew the gasket on the drivers side and I have stage 8's holding them in.
Old Dec 15, 2010 | 05:51 PM
Sheriff420's Avatar
Sheriff420
I got it fixed today. At least I hope I did. And now I feel like frosty the snowman.
I put my old Champion truck plugs back in there and ditched the heat shields too because I get spark knock every now and then depending on the tune and the gas I get. I assumed that the .065 gap on the Bosch Platinum +4 might have something to do with it.
I also figured that there would never be a better time to change the plugs then when the header was off on the hard side of the engine.
I modified a wrench and anyone that is thinking of getting shorty headers should do this to a wrench because it made things so much easier.
Oh, and it's really easy to hang out in one spot a second too long and blow a hole in that paper thin metal, you can see where I did it twice in the picture.
If you're going to modify a wrench yourself then either wear a gas mask while you do it or hold your breath, weld quickly, get away then breath. When you weld chrome vanadium it puts off toxic fumes.
