winch related question
Yep, as I stated above, rule is 1.5x the weight of the truck (so assuming a 6000# truck that would dictate a 9000# winch MINIMUM), HOWEVER your friend would probably not have burned out the winch had he used a ****** block, which dramatically increases the pulling capacity of a winch (although it negatively effects the speed at which the winch operates - physics 101, LOL)...
The ****** block is great, yes, but each one you use takes up more cable. If you have a 100' cable, and want to use one ****** block, you're only looking at being able to attach to something about 45' away. So, use blocks whenever you can, but there is a very good chance that you will need a lot of cable and/or chain in order to do so. Spend the extra $100 or so and get a stronger winch (you won't regret it)
You can always get a Pull Pal or other brand winch anchor:
Personally, the only place I am off-road where I'm in deep woods and would have a plethora of trees around me would be crossing a plowed field up at the farm. If I got stuck in one of the fields, I could just go fire up the tractor.
I carry two ****** blocks, one 27,000# rated and one 19,000# rated, in a heavy duty canvas bag I have in my tool box full of recovery gear. (You don't wanna know what they cost). I also carry an 8000# rated one in my ATV. I likes my ****** blocks.
I don't think I've ever needed one to increase my winch's capacity, but I've used them many a time when I couldn't line up my truck for a straight pull. They are indispensable for being able to pull safely at an angle!
I think that it may have to do with my being from AZ that I think you need more cable, and will not be able to pound anything into the ground. In most places, the ground is literally solid rock, and there are no trees.
Just take a look at the google maps satellite view of AZ. It's like looking the the moon.
