will a motor from a 99 1500 fit an 01 directly?
Old Dec 14, 2010 | 01:52 AM
vikingdiesel's Avatar
vikingdiesel
Default will a motor from a 99 1500 fit an 01 directly?
I know the motor will fit, but is all the electrical the same? Its a 5.9l coming from a 1999 going to a 2001 with a 5.9, I just want to know if its identical, or are the harnesses different.
Old Dec 14, 2010 | 03:55 AM
99dodge360's Avatar
99dodge360
The engine in my 99 came from an 01. The only thing different was the oil pressure sending unit plug. I changed out the sending unit and everything worked perfectly. I was told that this is not always the case and that usually it never happens.
Old Dec 14, 2010 | 06:17 AM
newman1367's Avatar
newman1367
Default emissions testing
you should be o.k., but if you have emissions testing in your area and a strict enforcer, they will notice an older engine in a newer pickup. That's an automatic fail.
Old Dec 14, 2010 | 03:16 PM
99dodge318's Avatar
99dodge318
yes they should be the same, i would keep your intake manifold though just in case. and no one will be able to tell, they were exactly the same casting.
