Fix hole in grease boot???
Old Jun 13, 2005 | 02:01 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Fix hole in grease boot???
I put my lift on this weekend (more on this later), but I noticed a problem as I was installing stuff on the front.
I greased everything up, and noticed that I have a pin size hole in the grease boot at the end of the drag link (passenger side). When I pump grease into the zerk, it comes out that tiny hole. I went to Dodge this morning to get a new replacement boot, and they said that it is all pressed together, so you have to buy a complete new drag link. It is not too expensive ($65), but it looks like a pain to change it out, plus I would have to get another alignment I think (since it is part of the steering assembly). Anyone know a way to fix a tiny hole in a rubber boot so that it will hold the grease in so I don't have to replace the whole drag link?
Old Jun 13, 2005 | 02:34 PM
steve05ram360's Avatar
steve05ram360
Default RE: Fix hole in grease boot???
here's what I would try... go get a inner tube repair kit and get the glue that is used for attaching the patch and put that on there, that stuff is supposed to seal rubber...
Old Jun 13, 2005 | 03:21 PM
Silver_Dodge
That's not a bad idea. I'll give that a try.
