P0455-evap !!!!
Old Dec 21, 2010 | 11:09 AM
Old Dodge 1's Avatar
Old Dodge 1
Question P0455-evap !!!!
Woke up to the new code this morning from the computer. Does anyone have any experience with this? I just need a little help being pointed in the right direction to fund a fix.
Thanks for help.
Old Dec 21, 2010 | 11:32 AM
EndIsNear's Avatar
EndIsNear
Thanks for help.
In the engine bay, passenger side. Check the hoses
Old Dec 21, 2010 | 12:30 PM
matty675's Avatar
matty675
its the purge solenoid on the drivers side of the manifold. it has 2 vac hoses and 1 electrical connector. take it off, shake it, and see if charcoal comes out. if so your canister is likely busted, either buy a new canister, blow out all the lines and buy a new solenoid.
or just remove the canister and allow the gas vapor to vent into the air and buy a new solenoid, no CEL. prevents any charcoal particles from ever getting into your engine again
if no charcoal is present, replace the solenoid
Old Dec 21, 2010 | 01:23 PM
Old Dodge 1
Smile
Thanks for your help on this, I will give it a try.
Old Dec 21, 2010 | 03:47 PM
ferguson30's Avatar
ferguson30
Mine had the leak on the rubber hoses on the top of the canisters on the passenger side of the frame. I had to disconnect it and pull it down enough to see the cracks. A couple of hoses and clamps, and the error code has been gone for several months.
