4X4 car wash
Old Dec 23, 2010 | 11:28 PM
aszarek001's Avatar
aszarek001
Default 4X4 car wash
I have a 2001 Ram 1500 4x4 and recently whenever I go through a car wash my 4x4 light goes on. It's not the normal brightness, it's kinda dim, but it's on.
When I'm out of the car wash and back on the road, I seem to notice more road noise which makes me think the 4x4 is engaged (but maybe I'm just hearing things). Eventually the light goes off and from what I can tell its back in 2 wheel drive.
If it helps any, when I go into the car wash the truck is in neutral, and all the wheels are rolling as its pulled through the wash.
Does anyone have any suggestions on what this could be?
Thanks
Old Dec 23, 2010 | 11:48 PM
Sheriff420's Avatar
Sheriff420
A not so water tight connection for the plug on the 4x4 switch on the cad unit maybe?
Unplug that thing, spray some contact cleaner in the end of the sensor and the pigtail, put some dielectric grease inside it, plug it back in then slop some liquid electric tape on the back of the pigtail where the wires go into it at.
Old Dec 24, 2010 | 09:02 AM
dhvaughan's Avatar
dhvaughan
^ yep. perfect answer.
to understand and troubleshoot the cad system read this...
and understand that the collar slides back and forth under vacuum command.
vac on one hose in 2wd, vac on the other in 4wd.
very simple, but prone to fail.
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Dec 24, 2010 | 09:49 AM
zman17's Avatar
zman17
Retired Moderator - RIP
That's strange, I just had something weird happen at the car wash too ten minutes ago. When I pulled in, my truck was white. When I left it was dark green. LOL Merry Christmas.
Old Dec 24, 2010 | 11:29 AM
dhvaughan's Avatar
dhvaughan
FIX YOUR PLENUM, REPLACE FRONT O2 SENSOR AND CAT.
and POST YOUR CAR WASH INFORMATION IF YOU WANT ANY HELP !!!!!
LOL, merry christmas to all.
Old Dec 24, 2010 | 11:36 AM
zman17's Avatar
zman17
The car wash mod only works after driving on roads that have salt on them for some reason. Maybe a car wash DIY sticky is in order. LOL
