Will '96 46re Auto fit '98?
Old Jan 5, 2011 | 10:30 AM
med's Avatar
med
Default Will '96 46re Auto fit '98?
Where can you find information on if a '96 46re auto tran will fit into a '98?
Old Jan 5, 2011 | 03:36 PM
95RAM360's Avatar
95RAM360
it will fit...as LONG AS YOU KNOW ITS A 46RE........the 94-95 have a 46RH, which is different (only minor things though) but you NEED a 46RE....any 46RE will bolt up to it....
Old Jan 6, 2011 | 06:14 PM
jasonw's Avatar
jasonw
Site Moderator
It may bolt up, but the wiring will be different.
Old Jan 6, 2011 | 06:31 PM
Adobedude's Avatar
Adobedude
From Martin Saine:
All 46RE's are not the same. Basically, the short form is that '96-99 Dakota and Durango interchange. '96-99 Rams interchange.
You can use a Dakota case in a Ram without problems, but putting a Ram case in a Dakota or Durango is a headache. You'll need to re-route the cooler lines or remove the offending bosses. If your Dakota/Durango is a 4 x 4, the Ram case will not allow bolting up the IFS bracketry and will lead to broken front diff and other suspension parts.
Martin would know.
EDIT: Martin is the guy whom built all the transmissions for Dan Arcand (Fastman)
