Transmission Fluid Capacity
Old Jan 8, 2011 | 01:04 AM
grox's Avatar
grox
Haynes recommends adding 1.5 quarts then one pint at a time until filled.
Old Jan 8, 2011 | 09:44 AM
grox's Avatar
grox
You also need to remember that the fluid level is temperature dependent, so when cold and running, it is "full" when at the lowest mark.
Old Jan 8, 2011 | 09:59 AM
mjonesjr's Avatar
mjonesjr
I got'er done.
It took about 5.5 quarts. I let the transmission drain without the pan for about 45 minutes.
I also moved my tranny temp sensor to the line going coming from the trans and going to the radiator and now my gauge won't read. I would hope that it is because the trans is not getting above 100* (where my gauge starts). I am going to add a second temp sensor back in the spot I had it originally and put a switch to toggle between them.
Old Jan 8, 2011 | 01:36 PM
PurplDodge's Avatar
PurplDodge
Its so damn cold out and my gauge never gets above 130*. And thats in the front servo port, measuring the temp inside the trans. So I would think that the line coming from the cooler doesnt get above 100*
Old Jan 8, 2011 | 04:06 PM
mjonesjr's Avatar
mjonesjr
I have the sensor in the line that comes from the transmission to the radiator, before it his the coolers (radiator and external).
I had the sensor in the front servo port, but moved it so I can put in a second sensor.
Like I said, I am going to add a second sensor to the front servo port.
Old Jan 8, 2011 | 04:52 PM
CPTAFW163's Avatar
CPTAFW163
Mine took 10 quarts. I had the front jacked up and the pan was dropped for 4 days. Reason being is I drilled and installed the drain plug on the wrong side. So I could not get the pan back on. Then i got a Derale +2 qt capacity cooling pan.
So I had it sitting for a WHILE. Maybe it was more than that. <easure fluid in neutral and running at operating temp.
Old Jan 8, 2011 | 07:05 PM
dipsherry's Avatar
dipsherry
ok not trying to thread jack but i woke up early today and before i left for work i made the girlfriend drive up and get me 6 more quarts of atf+4 so i drained my pan again and filled it back up wanted to get the lucas out before i drove it hope it didnt do to mucch damage...i bet it was a funny sight 4 am and i am outside draining my trans pan again...
Old Jan 8, 2011 | 07:25 PM
matty675's Avatar
matty675
hahaha atleast someone is smart enough to heed the warnings
Old Jan 9, 2011 | 12:06 AM
dipsherry's Avatar
dipsherry
yeah dont mind the frost bite from -4 degrees this morning lol
Old Jan 9, 2011 | 12:56 AM
G&L01's Avatar
G&L01
Uh oh.... I'm seeing all these warnings about making sure you use ATF+4. I'm pretty sure I put plain ol ATF in mine...
