Can anyone give some advice?
Old Jan 10, 2011 | 06:59 PM
bobbyd26's Avatar
bobbyd26
Default Can anyone give some advice?
I have a 2001 dodge ram 1500 5.9 v8. I recently started hearing a sort of grinding sound coming from what sounds like the engine but not sure. It only grinds when i have the truck in either drive or reverse, and when im at a complete stop. Somtimes it will continue for a second when i let my foot off the brake and begin to accelerate. Its not a continuous grinding it grinds in spirts. It sounds like metal grinding and sometimes when the grind gets loud it actually makes the truck jump and today for the first time the truck jumped hard enough to stall. It started back up and drove fine however the grinding is still there. No one seems to know what it could be. Has anyone heard of this before??
Old Jan 10, 2011 | 09:19 PM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the 2nd gen section (1994-2001 Dodge Rams), get you some help.
Old Jan 10, 2011 | 09:28 PM
matty675's Avatar
matty675
any smells?
Old Jan 10, 2011 | 09:35 PM
bobbyd26's Avatar
bobbyd26
Thanks. And no I haven't smelt anything
Old Jan 11, 2011 | 10:38 AM
dodgeboy1979's Avatar
dodgeboy1979
if it grinds under load then the best thing to do is have someone slowly drive the truck while one person sits under the hood trying to pinpoint the noise. You say it grinds in reverse so i would drive in reverse for the test as your hood will be up and in the way.
Old Jan 11, 2011 | 10:48 AM
bobbyd26's Avatar
bobbyd26
Thanks will do. Im just praying its not my tranny. I also just had my check engine light pop up yesterday with a p1740 code. From what im being told this is the end of my transmission.
