bad miss
Old Jan 19, 2011 | 05:29 PM
darkspaceboy's Avatar
darkspaceboy
Default bad miss
ok i got a problem with my 97 ram. it was starting to get bad gas mileage so i replaced them with Champion Double Platinum Spark Plug. Now its all but 2 cylinders are missing and is only getting 6.4 MPG. at idle it knocks, and when you gun it it misses bad. theirs black **** spiting out that smells like water. and is burning rich. now i know it has a bad o2 sensor but there is no cat. we were tanking maybe the wires, cap, and rotor might be bad but when i was googleing some things i cam across a post on hear from a guy with a 2000 dodge and it almost sounded like the same thing. but at the same time i don't thank so. so i figured i would ask and see what you all have to say. and yes for those of you still around this is the same dodge that had the trans problems after i had it in a mud puddle up to the doors. i did get the trans fixed. and as you can see it has a few other bugs.
thanks for taking the time to read and respond if you do
Old Jan 19, 2011 | 05:54 PM
95RAM360's Avatar
95RAM360
your plenum is blown. Do a search here, its a problem that will happen in all 2nd gen rams. and theres 49875426987235687356708356837560730546730456735670 3485767830586703487563574603845670735406356 threads on it.
Old Jan 19, 2011 | 06:54 PM
darkspaceboy
ok. ty. i forgot to add it also knocks really bad with overdrive on but if it is off its fine
Old Jan 19, 2011 | 07:06 PM
darkspaceboy
ok from the search im guessing your talking about seeing if its dirty or bad gasket in there. i would bet my right nut it is. it has never been taken off nor has it been cleaned.
