Tires
Old Jan 24, 2011 | 06:39 PM
captaincasey123's Avatar
captaincasey123
Question Tires
Trying to put super swampers on my truck. Any one put um on a stock lift 2wd ram before? Want to know if i'll clear 31x12.50. Thanks guys
Old Jan 24, 2011 | 06:48 PM
redheadhunter21's Avatar
redheadhunter21
it will depend on rim bs, if not it will rub the plastic inner fender and the bumper plastics, if its a beater truck go for it, if anything a spacer might help
Old Jan 24, 2011 | 11:06 PM
tweeker909's Avatar
tweeker909
Like to try and clear 33" tires. Who makes 2wd lifts? preferb spindles? over coils and spacers if available? How much for the rear to clear?
Old Jan 24, 2011 | 11:20 PM
notanexit7's Avatar
notanexit7
I think fabtech has a spindle lift kit but they will make your front wheels stick out farther than your rear ones if I'm not mistaken.
Old Jan 25, 2011 | 01:09 AM
redheadhunter21
doetsch makes 3in lift spindles and that should clear your 33's without a problem, the rear will clear without a problem, you will only need to lift the back to match the front...some people like the front higher and will leave it like that, some prefer perfect level or factory rake, and will put blocks or add-a-leaf to bring it up.
I got a cheap kit off of ebay that came with 2.5" springs for the front and 1.75" shackles for the rear, and I plan on gettin some spindles in the future and a add-a-leaf to get the truck up higher
PS...pretty much any spindle will bring the front tires out a little, thebigredone has a project truck that has the spindles installed and you can find his pics to see how far they stick out...about an inch
Old Jan 25, 2011 | 01:48 AM
dipsherry's Avatar
dipsherry
^ditto^ pretty much everthing said so far is what i know.. my truck i have 2.5 inch coils on front and 2 inch block out back and i clear 315/75/16 with only a little rub on the upper control arm at full lock.. spindles will have your wheels sticking out a little further...
