PO420 code
Old Jan 27, 2011 | 05:04 PM
J415's Avatar
J415
Originally Posted by zman17
A 420 code is the one before the cat.......
+1 Y'up...0423 is after the cat
Old Jan 27, 2011 | 07:53 PM
Mad_Scientist's Avatar
Mad_Scientist
Originally Posted by Jamie71
Catalyst System Efficiency Below Threshold (Bank 1).
How does the pre cat sensor read catalyst efficiency if its sensing exhaust BEFORE the cat. Just my .02, but the post cat sensor makes more sense with the way the code is worded
Old Jan 27, 2011 | 10:06 PM
pcfixerpro's Avatar
pcfixerpro
Exactly, Someone gets the big picture
http://www.p0420.com/ <-- Reading material for the ****ter
Rear o2 is what is throwing the code, but not necessarly the reason for the code.
Old Jan 27, 2011 | 11:40 PM
Dodgeman000's Avatar
Dodgeman000
Jesus Christ, p0420 is not an o2 sensor code. Its for catalytic converter efficiency. Basically your cat is dead. Meaning its no long cleaning the emissions from your engine. Don't replace your 02 sensor your wasting your money. You should replace (or hollow out) your cat. BTW If you hollow it out your going to get a cel.
Old Jan 27, 2011 | 11:47 PM
Mad_Scientist
Po420 IS an o2 sensor code. The catalyst efficiency is read by the post cat o2 sensor. It is possible that the o2 is lying to the pcm because it is faulty. Therefore the root of the problem could be that the o2 is bad or the cat is sh!tting the bed.
Only reason I asserted my opinion on the meaning of the code is to shoot down the naysayers with some good ol' logic. My money is on the cat being clogged by a blown plenum, but we cant rule the o2 out of the equation.
Edit: If you gut your cat there is a quick and painless way to eliminate the CEL. Use the spark plug non-fouler trick which can be found in the faqs section here (works for me and many others on this site). It is quick, easy and will set you back a whopping 5$. NOTE: If you must pass smog emissions (i.e. they put a hose on your exhaust) you will not pass with a gutted cat
Old Jan 28, 2011 | 02:25 AM
93grandzj's Avatar
93grandzj
well if your replacing the cat just do your sensors too. might find better fuel efficiency with new sensors and new cat. BTW if you have problem with emissions move to a state without them. ha ha +1 for Minnesota.
Old Jan 28, 2011 | 02:58 AM
Mad_Scientist
Dont fix what aint broke. If your o2s are good, leave them there.
Old Jan 28, 2011 | 07:54 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Right out of our own FAQ section, https://dodgeforum.com/forum/1582321-post6.html. 1/1 means bank1/ sensor1. We can argue all day about what catalytic converter efficiency means, but 1/1 is the precat sensor.
Old Jan 28, 2011 | 09:51 AM
Jamie71's Avatar
Jamie71
Everytime i check different sites about the code it sayd it is the o2 sensor not the cat it self, so I am taking it is the sensor just before the cat.
Old Jan 28, 2011 | 09:54 AM
Jamie71's Avatar
Jamie71
So what is it- the cat or the o2 sensor? I think it is the o2 sensor.
