wacky vents check valve
Old Jan 29, 2011 | 09:17 PM
Joey Buentello's Avatar
Joey Buentello
Default wacky vents check valve
Read an article about replacing the check valve at our firewall with a larger one from the dealer as the larger one would hold more vacuum.
the dealer didn't have it in stock and said the little vac check valve would hold the same ammount of vacuum.
Old Jan 30, 2011 | 08:29 AM
BIGBIRD85's Avatar
BIGBIRD85
whne my wacky vents start up, i just spray a good amount of WD-40 into the vacuum line with the truck running. i break it loose right there at that check valve. i end up doing it about 3 times a year!
Old Jan 30, 2011 | 02:40 PM
Joey Buentello
in to the vacuum line at what point?
Old Jan 30, 2011 | 03:42 PM
BIGBIRD85's Avatar
BIGBIRD85
i separate it at the check valve and spray it into the lines. with ever end sucks into the check valve.
Old Jan 30, 2011 | 04:16 PM
Joey Buentello
sounds like a plan
