remove lift or change gears for improved milage
Old Feb 4, 2011 | 07:34 AM
  #21
EricCartman's Avatar
EricCartman
Originally Posted by PurplDodge
Oh yeah, pull that lift off. Its an outdated look with the 15'' wheels.
It's also a helluva lot cheaper to buy new tires for too...
Old Feb 6, 2011 | 12:13 AM
  #22
newman1367's Avatar
newman1367
Originally Posted by FarmBoy428
shoot i'd say upgrade your gears to 4:56s or 5:13s an run 33's idk its a shot?
maybe cai if you dont have one that helps too, maybe find a mpg tuner
If he has the 318, it's a half ton. Which means he has a 9 1/4" rear. No 5.13's available. I'd keep the lift, go with 35's and 4.56's if it's a daily driver. I had 35's w/ 4.10 gears and it was alright, but 4.56's or 4.88's would be more fun.
Old Feb 6, 2011 | 12:23 AM
  #23
mdram43's Avatar
mdram43
in my opinion, those 4.11 gears are killing you more than that lift. the tires are definitely not helping, but moneywise: your going to pay to remove a lift that you already spent the money on, thus throwing you in the negative. If you sell the lift, your at 0. your mpgs might go up a little, but not as much as a lower gear ratio. Going with smaller tires would help, but theres more money to be spent just to save on the gas?
I would weigh each option vs money spent and money saved. the gear ratio is huge in the long run, as well as tire size.
if you go lower gear ratio, your definitely gonna need to run smaller tires...
is the money you spend really going to be worth the extra $20 saved in gas each week?
Old Feb 6, 2011 | 02:42 AM
  #24
iitywygms's Avatar
iitywygms
it's not just the money, or the gas milage. It is now my daily driver.
It barely fits in my garage, it is a pain to park, I go off road maybe twice a year and never get into anything serious anyway. It is harder on the tranny running huge tires.
I purchased the truck with the lift, so no money lost if I do it myself.
This is my plan. Remove the body lift and go with different rims and tires. Change from 35 inch tires to 33 inch. The 4.11 should be perfect with 33 inch tires.
Still have off road ability, and should save some money in gas.
On a side note. Where is the thread showing rims/tires/size/looks???
Old Feb 6, 2011 | 09:07 AM
  #25
grox's Avatar
grox
I know that in at least the 94 model year the 318 was offered in the 1500 and 2500.
