Voltage regulator?
Old Feb 3, 2011 | 09:26 PM
daleas88's Avatar
daleas88
Default Voltage regulator?
I have a 97 ram 1500 4x4 5.2auto trans and I believe my regulator is bad or going bad, when I lift my plow it makes the radio cut out and when I was plowing my voltage was at like 10 just idleing, I just pulled the alt off and replaced it with a 130 amp and it still did it, I don't wanna buy a PCM if I don't need it! Is there any way to install a external voltage regulator? And does it sound like that's the problem? Any help is GREATLY appreciated!
Old Feb 3, 2011 | 09:53 PM
Ugly1's Avatar
Ugly1
It could be your battery. Test that before you replace the regulator which I'm told is built into the computer. Could just be a bad bat pulling down the regulator.
Old Feb 3, 2011 | 11:54 PM
daleas88's Avatar
daleas88
I had the battery tested and it tested good in the vehicle I guess I could pull it and see, and yes you are correct, it's built in the comp! That y I want to avoid that!
Old Feb 4, 2011 | 02:05 AM
96magnumram's Avatar
96magnumram
I had a problem back in Dec where my voltage was dropping at idle...had the alternator tested and the diodes failed the test. Installed a new alternator. Drove it around for an hour, went to start it back up and got NOTHING, replaced it with a 27 series Duralast Gold and haven't had a problem since...jumped it off and drove it to my inlaws house and yanked the battery out...took it the the Zone and it was JUNK...SO I would second on having the battery tested OFF of the vehicle.
