96 ram 1500 4x4 track bar
Old Feb 11, 2011 | 06:39 PM
riced's Avatar
riced
Default 96 ram 1500 4x4 track bar
I baught my truck last May,it needed a track bar,no big deal easy to replace,good thing because I have replaced it twice and now needs another.I t always goes at the tie rod end, gets sloppy and the body moves before the wheels turn.What is the need for the tie rod end,is there axle roll?If not I am thinking of fabricating my own and put bushings on both ends.What do you think?
Old Feb 11, 2011 | 06:59 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out our Ram Section!!
Dusty
Old Feb 11, 2011 | 08:21 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Feb 11, 2011 | 08:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand are you buying?
Old Feb 11, 2011 | 10:55 PM
BackwoodsRam's Avatar
BackwoodsRam
go to top gun customz and order thier track bar and brackket its a little pricey but it eleminates the tie rod end and uses a heim joint end, plus the bracket is way stronger. and mine only took about 3 hrs to install.
oh yea its also adjustable for 4"-8" of lift
Old Feb 11, 2011 | 11:11 PM
zman17's Avatar
zman17
That won't help unless he has 4-8"s of lift. Thuren makes one for 0-3"s and there is also this http://www.vulcanperformance.com/Luk...grade-p/ll.htm
