finally!
Old Feb 13, 2011 | 06:21 PM
penski61's Avatar
penski61
Default maintanence almost done
finally got the truck all back together re-did the entire front suspension , front and rear brakes , diff oil change , changed pass side door lock actuator , oil change , and got a security system installed
truck rides awesome , i had to tweak the alignment a bit after the initial install
but all is good now
i just need to change out the trans fluid and filter and was curious to know if anyone knows if they sell auto +4 in gallons or just in quarts to do a change its about $80 worth of fluid
the other thing i need to find is the rubber air intake flex tube that goes from the plastic by the battery to the air filter box
thanks
98 2wd 3/4ton 2500 with a v10
Old Feb 18, 2011 | 11:43 AM
penski61's Avatar
penski61
scored napa brand atf +4 today , internet price is $4.49 which was the best i could find
went to the store and found they had an old sticker on the shelf listing it for $3.79 they were goin to charge me the $4.49 but showed them the sticker so they gave me the sticker price so i got out of there with a case of atf+4 and gallon of PS fluid for $60 !!
only thing left to do is get some HD rear shocks
