need hlpe on right tire size
Old Jun 23, 2005 | 02:58 AM
BluevenomGT's Avatar
BluevenomGT
Default need hlpe on right tire size
Right now I have 245-75-16 on my truck....but I want a wider tire to make it look sporty.....do I need to change the 75 to a lower number or what.....I don't really understand if I can just get the wider tire with a 285-75-16 and look sporty like I want. I just don't want the wall of the tire to look like the 20's on the new dodge....hopefully someone understands what I am asking.
John
Old Jun 23, 2005 | 11:24 AM
greenmachine's Avatar
greenmachine
Default RE: need hlpe on right tire size
The 275 is the tire height, and yes you will need to make the 75 a lower number to give the truck a wider stance. I have 50's on mine and it looks mean. PLEASE dont put a w i d e tire on a skinny rim , just as bad as a skinny tire on a fat rim.
Old Jun 23, 2005 | 11:35 AM
krikitz's Avatar
krikitz
im preeeeeetty sure the 2 hundred number is the width of the tire
the 75 that your runnin right now is aspect ratio, it tells you how much rubber you got from the rim to the edge of the tire
if im guessin the look ur goin for right, your gonna wanna do like green machine said and go to a 70 or lower, but thatll change the height of the tire (not the width)
but yea definetly check to see if your wheels can handle a wider tire, i doubt they can if theyre stock so ur gonna hafta put some new wheels on that thing too
Old Jul 12, 2005 | 11:37 PM
Mr.Fancypants's Avatar
Mr.Fancypants
Right now your tires are 245 mm wide(about 9.5 inches) the 75 means the sidewall is 75% of the width and the 16 is your rim size(16")
Old Jul 13, 2005 | 01:42 AM
Dodge4x4810's Avatar
Dodge4x4810
i have 305's on my '99 Ram 4x4 quad cab and they only rub in the front when you turn the tires all the way. They look great
Old Jul 13, 2005 | 01:51 AM
mxmancr250's Avatar
mxmancr250
If you are wanting your tires to look like 20's you might as well just get 20's then because if you go with low profile tires on your 16's it will most likely look kinda funny.
