rims ?
Old Feb 20, 2011 | 03:33 PM
yellowtruck's Avatar
yellowtruck
Default rims ?
Is the bolt pattern the same on newer RAM rims then on my 96. I want to take 20" rims from a 2004.
Also is there any other rims that will fit on a dodge like Ford or jeep
Old Feb 20, 2011 | 03:44 PM
dodgeram07's Avatar
dodgeram07
if were talking about half ton,, its 5x5.5 bolt pattern
if your say you want to take 20in wheels off a 1500 dodge ram they will bolt up
if you have a 4x4 you will not have a problem
if you have a 2wd the new rims will not work unless you use a spacer do to the bearing sytle and the grease cap
and yes ford used the 5x5.5 bolt pattern
older jeeps with the dana 44's had 5x5.5 bolt pattern
but yj,xj,zj,jk...ect wheels will not bolt up
a little more truck info would be great,,, please fill out your truck info in your sig, or the top righ in the info place
Old Feb 20, 2011 | 03:45 PM
dodgeram07's Avatar
dodgeram07
your use this
http://www.roadkillcustoms.com/hot-r...e-Database.asp
Old Feb 20, 2011 | 08:05 PM
romadramowner's Avatar
romadramowner
I know some consider it a curse word on here but 4wheelparts has a good guide for it on their site. Click on the bolt pattern guide.
http://www.4wheelparts.com/WheelFinder.aspx
