flasher relay is goin crazy
Old Feb 24, 2011 | 05:19 AM
stands2p's Avatar
stands2p
ok so you have the updated combo flasher.now you can use the procedures outlined in the 01 manual under lamps to seek out the gremlin.
Old Mar 10, 2013 | 06:33 AM
autoexpress's Avatar
autoexpress
I may know the answer to this! I had the same problem. It happens when both front and rear bulbs aren't working. When one goes out, it fast blinks. When both go out, it buzzes. In my case, at both front and rear right side, corrosion made bad contact, causing heat, melting the leads from the bulbs and recessing them into the plastic base of the bulbs. I found out by wiggling one bulb, which made it go from buzzing to fast blink. I cleaned the contacts, replaced the bulbs and no more buzzing.
Old Apr 6, 2013 | 07:28 PM
gobbledott's Avatar
gobbledott
Having similar problems with my turn signals. Just got a 2004 Ram 3500, and the right side turn signal just began flashing rapidly. I replaced the right side bulb, and it still is flashing rapidly. Anyone with a thought??
Old Apr 6, 2013 | 10:19 PM
newman1367's Avatar
newman1367
Turn signal fluid, FILL THE TURN SIGNAL FLUID!! You probably replaced the wrong bulb.
