motor mount heat shield
Old Mar 10, 2011 | 08:37 PM
seabass202's Avatar
seabass202
Default motor mount heat shield
I have noticed that aftermarket motor mounts do not come with heat shields. At napa, the mounts have a hole where the heat shield could be repined if you were to take the time to separate it from the old mount. other brands I have seen have no holes. It seems just difficult enough that I doubt most garages and diyer's do this. I have just changed mine out and didn't reinstall the heat shield and just want your thoughts on this. I am not opposed to tearing back into them if necessary. Thank You.
Old Mar 10, 2011 | 08:42 PM
PurplDodge's Avatar
PurplDodge
Why couldnt you just bolt the old heat sheilds up to the new motor mounts?
'Ma Mopar put them there for a reason, to keep the exhaust manifolds from melting the rubber motor mounts.
