i did the same on my 95 ram 1500 ...rear shackles and hangers for a 4 inch drop...my torque spec was...i got them as tight as i could without stripping the bolt...use your best judgement they just need to be tight like dont strip the bolts off...tight is tight...otherwise you could look up some torque specs based on bolt size and all that if you wanted too
I had to cut the bolt on each side of shackle on mine. When the spring shop tried to press the bolt out the budging came out lol. I don't know it got the seized up.
