TPS Calibration
Old Mar 31, 2011 | 09:39 PM
Demoes4x's Avatar
Demoes4x
Default TPS Calibration
Does the TPS need to be calibrated/set by a scanning tool after replacement? I was told it did.
Thanks in advanced.
Old Mar 31, 2011 | 10:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It does not have to be set with a scan tool. If you removed the neg battery cable while you installed it, the pcm will reset, and you'll be fine.
Old Mar 31, 2011 | 10:30 PM
Demoes4x's Avatar
Demoes4x
The manual does not mention it and dealership told me it did... Go figure.
Thanks Zman
Old Mar 31, 2011 | 10:35 PM
zman17's Avatar
zman17
There is one thing you can do to it. Hold on let me find it.
I'll be damned, can't find it. It's a mod you can do to make sure it's set at the correct voltage. Oh well sorry. If I find it, I'll post it here.
Old Mar 31, 2011 | 10:50 PM
zman17's Avatar
zman17
Found it, it's in here scroll down to tps modification. All kinds of other good stuff there too. http://www.bionicdodge.com/Download/...d%20Tricks.pdf
Old Mar 31, 2011 | 10:52 PM
aim4squirrels's Avatar
aim4squirrels
Drill out the 2 brass guides where the mounting screws go. Screw it into the mount ing point, but not so tight that you can't move it a bit. Then back probe the center wire with a voltmeter, and set it to .01 volts. Twist the tps a bit until it reads as close to .75 volts as you can. Tighten down the torx screws.
Old Mar 31, 2011 | 11:04 PM
Demoes4x's Avatar
Demoes4x
Great info guys thanks. I'll be working on this tomorrow.
