Fuel sync problems
Old Apr 10, 2011 | 02:52 PM
  #21
dodgeboy7's Avatar
dodgeboy7
Also there is no check engine light and i did swap out the pcm with one out my donor truck and the pick up sensor
Old Apr 10, 2011 | 03:21 PM
  #22
xjarhead69's Avatar
xjarhead69
Originally Posted by dodgeboy7
I got the crank sensor at napa. The clamp is holding fine i try moving it after i set it and would not turn.
I had to replace the motor with a long block about 20,000 ago so timing chain should be like new.
Get that Napa sensor out of there and get an OEM one.
I had to replace mine when i did my tranny because it got pinched between bellhouseing and block when putting it back together.
After a week or so my truck just started shutting down between 5 and 8 minutes after you first started it.
Wait about a minute it would restart and no more issues, unless you let it cool completely down.
Never received any codes.
It took six monthes of testing, till I just went ahead and replaced the Napa sensor with OEM and problem was gone.
That was over year ago and no issues since.
Dave
Old Apr 12, 2011 | 04:22 PM
  #23
dodgeboy7's Avatar
dodgeboy7
Found out by going though the snap on scanner i have a misfire on cyc 3 but it dose not trip my light. My buddy friend "dodge tech" said the reason why the fuel sync keeps jumping around is b/c of the misfire and it trying to fix it. So i doing a tune up this weekend and see if it stops. If not i guess i do a leak down test for crank cyc head.
Old Oct 3, 2012 | 07:27 PM
  #24
Tailgate101's Avatar
Tailgate101
I am having a very similar problem. I'm wondering how yours turned out. You can probably find the thread I started hear under my screen name.
