my truck keeps dieing
Old Jun 30, 2005 | 02:41 AM
navydude202's Avatar
navydude202
Default my truck keeps dieing
hi people im new to the hole forum thing and i dont know if this is the right place for this question but hopefully i can get some help
i have a 97 ram 5.9 litre engine
latly it keeps dieing whenever i let go of the gas and somtimes it smokes. at times it goes away and runs fine but usally its messed up. i thought it might be a blown head gasket but there is no water in my oil and visa versa. i also gave it a tune up and that didnt help. a buddy of mine suggested my o2 sensor, could that cause this problem?
Old Jun 30, 2005 | 03:45 AM
steve05ram360's Avatar
steve05ram360
Default RE: my truck keeps dieing
clean the throttle body and the idle control valve all of the ports that are going to it.. there is at least 1 small one. this should fix your problem...
edit: while your in there, look down the intake manifold on the bottom of the intake for any signs of oil pooling on the bottom. if there is... you have a leaky plenum gasket... this is a common failure and easy to fix.
Old Jun 30, 2005 | 04:09 AM
navydude202
thanks ill try that oh and about how long does it take to take off the throttle body?
Old Jun 30, 2005 | 01:12 PM
steve05ram360
5 miniutes or so... 3 electrical connectors, 4 bolts and 3 throttle cables (if you have cruise and an AT)
get a new gasket too
Old Jul 5, 2005 | 08:36 PM
navydude202
thank you ill try that
