wiring 12v power to 7pin connector help
Subscribe
Apr 17, 2011 | 02:35 PM
have a 95 ram w/ a 7 way trailer connector At the end of last season everything worked great. All lights, brakes, etc. work but I now have no 12v power going into connector truck side. My question is would there be a fuse somewhere along that line that I cant find? once it leaves the rear of truck i can fallow it down frame and then lose it somewhere around driver side front. And say if there is no fuse should there be one? can i cut the wire where i lose it and wire it to the pos. battery? any help would be great
Reply 0
Apr 17, 2011 | 02:59 PM
this may be different for yours, but im my '01 i have 2 fuses, 1 that is in the pdc under the hood, and one to the right of the master cylinder behind the pdc. the one in the pdc is a 40a and the one behind the pdc is a 20a. the 20a supplies the 12 volt power, the 40a supplies the power for the entire brake controller setup.
Reply 0
Apr 17, 2011 | 04:14 PM
all i could find is a 30amp in pdc and then there is a wire coming off of positive w/ a 30 blade fuse running to brake controller. I looked and looked where could it be I have to be missing something would dodge really make life this hard
Reply 0
Apr 17, 2011 | 04:22 PM
ill go out and take some pics of mine, ill post them in a few for ya!
Reply 0
Apr 17, 2011 | 05:46 PM
here are your photo's sir! i took some of the pdc cover, and of the fuses themselves. hope they help you, if they dont you could always run a 20a fused power wire from the battery, to the 7-way round...
Reply 0
Apr 17, 2011 | 07:39 PM
thanks for the time and the photos. Yes that is the fuse that im looking for. does that come stock from dodge or could it be added by the original owner? dumb question cause anyone could add it. I couldnt imagine snow catching that wire and pulling it out of engine compartment. I just dont see it being riped out of engine compartment. It had to be run by previous owner... some people just shouldnt rig things. thank you again for the pics. I thought i was losing my mind
Reply 0
Apr 17, 2011 | 08:40 PM
im gonna say thats a factory run wire, or it was professionaly installed wire. im not sure because it was there when i bought the truck. it has the factory tow package, so im almost positive its factory. truck also had a brake controller when i bought it. i have moved it and rewired it a couple times. i have also rewired the 7 way round twice, first time was because the original was corroded, and the 2nd time was because someone decided to be a douche and steal my 7 way and about 6 inches of the harness it plugs into. so im the guy to go to for trailer wiring issues....lol
Reply 0
Subscribe
