Rod Bearing Wear
Old Apr 20, 2011 | 12:42 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
Originally Posted by VWandDodge
And please spay or neuter your pets.
Says the guy who looks nothing like Bob Barker. =)
Old Apr 20, 2011 | 01:02 PM
RamNJeep's Avatar
RamNJeep
I ordered new rings and rod bearings, they already showed up yesterday (Summits warehouse is NV is next day ground shipping to me).
Anybody know a secret to getting all the carbon off the pistons? It is pretty baked on there. maybe a scotchbrite scuff pad? I thought about breaking one of my old rings to scrape in the ring lands but...
And all of my pets have been spayed / neutered.
Oh and I popped the main caps off (one at a time, the engine is still mounted in the truck) and they look serviceable, what is the average life of a plain bearing?
Old Apr 20, 2011 | 01:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Carbon can be a bear to remove. Try using a blade to scrape it off or even oven cleaner. If using oven cleaner, be sure to do this in a well ventilated area and let it soak for a while.
Old Apr 20, 2011 | 01:20 PM
RamNJeep's Avatar
RamNJeep
so far I have tried Oven-Off, carb cleaner, and the solvent in my little 3 gallon solvent tank (although it has been in there for a bit). may have to just keep on soakin 'em.
Old Apr 20, 2011 | 02:04 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Time for some Napalm.
Old Apr 20, 2011 | 02:37 PM
RamNJeep's Avatar
RamNJeep
hmmm, never thought of that. Im mixing some now. This may also be the solution to everyone fuel economy threads. just run napalm instead of $4 for a gallon of gas. easier than HHO. I bet with a TB spacer I can get 1000 miles to the gallon!
Old Apr 20, 2011 | 02:41 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
You forgot the Acetone!!!
Old Apr 20, 2011 | 03:01 PM
matty675's Avatar
matty675
you shouldnt be asking yourself how much more life the bearings and rings have in them. 200,000 miles was plenty of service for them. spend $100 and replace the bearings and rings, SINCE IT IS DISASSEMBLED!
so you have a bare block in your truck right now? might be easier if you took it out...
Old Apr 20, 2011 | 03:10 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
https://dodgeforum.com/forum/2484523-post12.html
Old Apr 20, 2011 | 03:19 PM
RamNJeep's Avatar
RamNJeep
yes, the only thing in the truck right now is the bare block and crank. Since it started as only a top end job, block is still in there. although the project has kinda escalated. I was planning on just leaving the mains since they are serviceable. Just wondered what the average life span was. and my engine stand is occupied with 454 right now for a friends Jeep...
