4WD indicator stays lit.
Old Apr 28, 2011 | 09:45 AM
MedicNathan's Avatar
MedicNathan
Default 4WD indicator stays lit.
Yesterday when I shifted out of 4WD I noticed that the light stays on, I haven't been able to get it to shut off since. I am fairly certain the the CAD is still working however, because when I'm in 2wd I can turn without the front axle clicking. I have good vacuum at for the line going down of the engine, I haven't check the other lines though, but as I said, I didn't think the cad would work without vacuum. Is this a dirty connection somewhere or is the truck telling me i have a 4wd problem?
Also 4wd does engage without any fuss
Old Apr 28, 2011 | 10:15 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You might check your vacuum lines at the CAD housing.
Sometimes they can break causing the 4WD light to come on.
Old Apr 28, 2011 | 01:13 PM
AdamR88's Avatar
AdamR88
i just solved this problem in my truck yesterday...vacuum line came loose
Old Apr 28, 2011 | 05:50 PM
dodgeboy1979's Avatar
dodgeboy1979
the little vaccuum unit on the axle itself may be stuck in the 4x4 position, it is only a switch on the inside of the axle housing. Might be worth a check.
