1998 Ram 2500 4x4 Rear end and Front end????
Old May 1, 2011 | 12:46 AM
Dogger11's Avatar
Dogger11
Default 1998 Ram 2500 4x4 Rear end and Front end????
How do I tell what Rear End and Front End I have in my 1998 Ram 2500 4x4? Is there any markings or anything?? Any help would be much appreciated!!!
Thanks
Old May 1, 2011 | 01:11 AM
Gerehead8's Avatar
Gerehead8
Both Dana 60's with the 360 V8.
Old May 1, 2011 | 01:23 AM
99dodge318's Avatar
99dodge318
it should say on a label under the hoo if its the stock hood, also on some trucks theres a build sheet glued to the inside of the glove box, again only if its the oem piece
Old May 1, 2011 | 01:14 PM
Dogger11's Avatar
Dogger11
Thanks everyone!!!!
Old May 2, 2011 | 02:07 PM
sungod's Avatar
sungod
Most likely 60 front and 70 rear. It could be a 80 in the rear depending on the config. As stated look under the hood. That is where I found my info. This site also has some good info on specs http://dodgeram.org/tech/specs/Ramspecs.htm
Old Dec 11, 2017 | 07:57 PM
Westside's Avatar
Westside
First thing I did was check lug nuts, all good
