Old Aug 6, 2015, 11:49 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
No brake or turn signal lights
Old May 1, 2011 | 03:01 PM
billchapjr's Avatar
billchapjr
Default No brake or turn signal lights
I have a Dodge Ram 1500 lost brake lights and all turn signal lights also flashers don't work. Brake light on back of cab does work. I do have lights when head lighs are on. Was towing a trailer whhen I lost every thing check all fuses. Any Ideas I can trouble shoot pretty good but this has me lost.
Help!
Old May 1, 2011 | 03:46 PM
botta's Avatar
botta
theres a switch in front of the brake pedal under the dash for the tail lights, in the steering col. there is the blinker and hazard switch, id check both of them. and the headlight switch gows bad in mine all the time. thats in the dash where u turn the headlights on.
Old May 1, 2011 | 09:01 PM
meanwhitemopar's Avatar
meanwhitemopar
Smash that 4way hazard light a good few times. If that is sticking... nothing will work .. happens to me all the time
Old May 4, 2011 | 10:15 PM
97_DodgeRam's Avatar
97_DodgeRam
Also if your trailer light hook up wasn't done the proper way then it can cause those symptoms. I have a 97 ram 1500 5.2 and the PO didn't have it done right, they just jimmy rigged it and never put a fuse-able link. Had it done by a garage and problem solved.
Old May 5, 2011 | 12:53 AM
autolockguy13's Avatar
autolockguy13
like ^he said^^^ check the wires that run down ur drivers side frame rail, take them out of the loom and inspect them, my previous owner did alot of funny things that i didnt get to find until it was too late and this was one of them! i had to re-run 2 wires all the way down the frame, to the drivers side taillight, then over to the passenger side because the wires were fried!
Old May 5, 2011 | 10:12 PM
Magnum4406's Avatar
Magnum4406
Multifunction switch. If playing with the hazard switch doesn't fix it (It has worked for me also) Then you will need to replace it.
