Quick little question.
Old May 1, 2011 | 07:41 PM
SweetTooth's Avatar
SweetTooth
Cool Quick little question.
So ever since I've replaced my Distributor/cap and new wires my truck has been driving very odd. Before I did all the wires and stuff my truck would have a huge hesitation issue. Once I replaced, it was fixed. But, it'll get up and go on a low speed, 0-30 but once it starts getting to about 50 or so on the highway, I try to pass cars and stuff, my truck doesn't want to accelerate at all. Example (close your eyes and pretend )
I'm turning over to pass a vehicle going about 65, and I get over into the other lane and my speed just drops and when I step on the gas, it doesn't want to accelerate right away.
When I replaced the distributor and cap did I do something that I shouldn't have? That was my first time ever doing anything like that. And when I replaced the cap it was basically just a feel around until it was in. On the 97 dodges you can't see what you're doing back there. I know the firing order is correct, and it's not throwing codes. So I'm confused on why it's doing this.
Old May 1, 2011 | 09:46 PM
xjarhead69's Avatar
xjarhead69
Did you actually pull the Distributor out?
If I remember correctly if you pull it then you have to have the fuel sync reset with DRB 3 scan tool or equivalent, thru dealer or a shop.
You can dowload the service manual from the faqs section and double check that.
Im at work and cant download it.
Dave
Old May 2, 2011 | 02:18 AM
jasonw's Avatar
jasonw
Site Moderator
Sounds normal to me when trying to accelerate in OD without giving it 100% throttle. Even 95% seems to make it want to still try and do it all in OD, which is terrible at everything except gas mileage (and isn't much better at that either).
