I need Wheel Help!!! Please!!!!!
Old May 4, 2011 | 10:57 PM
Dogger11's Avatar
Dogger11
Default I need Wheel Help!!! Please!!!!!
I would like to run a 20"x9" wheel with a 37" tire on a 98 Ram 2500 4wd, My problem is I don't know what offset to get? I went to my local Les Schwab and they said I need a 0 offset, but there is hardly any wheels that come in a 0 offset so my choices are limited according to Les Schwab. Les Schwab told me that if I went past 0 offset either way (positive or negative) That it wouldn't work. I dont see how 12mm + or - offset can make that big of a difference but what do I know!
I would like my tires to stick out past the fenders just a little bit to give it that aggressive stance but not too much!!
I was wondering if you guys could help me by posting a picture of your 98 ish Truck with the wheel size and offset.
Please Help!!!!!!!!!!!!!!!!!!!!!!!
Old May 5, 2011 | 12:00 AM
matty675's Avatar
matty675
ive never had a problem with offset. id just pick a set you like.
Old May 5, 2011 | 12:28 AM
edlucky1's Avatar
edlucky1
If your running 37" tires you obviously have it lifted. Most aftermarket kits specify an offset for their model. If you pieced together a kit I would just compare it to a kit that is close to it. Otherwise I'm not sure.
