need help with brake controller
Old May 12, 2011 | 04:59 PM
sullivanj04's Avatar
sullivanj04
Default need help with brake controller
I am installing a trailor brake controller I do not have to pakage what is a good place to pull power from is there anything switched with easy added somthingthat will only have power when the truck is on and where should I ground it thanks
Old May 12, 2011 | 06:01 PM
sullivanj04
Also any one know what wire to connect to at the brake peddle wire harness thanks
Old May 12, 2011 | 10:02 PM
sullivanj04
Any one know I don't have a multimeter all I need to know is what wire on the harness the clips to the brake peddle sensor has power when the peddle is pushed I figured the rest of it out thanks
