Front Axle Leak
Old Jul 6, 2005 | 11:45 AM
dwhipper61's Avatar
dwhipper61
Default Front Axle Leak
Hello,
I'm new here, and I have a question. My 99 Ram 1500 Sport 4x4 has developed a leak from the front axle. Between the front differential and the passenger side hub, there is a sensor??? I have no idea what it is, I am thinking it might be an ABS axle speed sensor or something. I can try to post a picture tomorrow of the part in question. It looks like it is leaking axle lube from a gasket where the cover attaches. Can someone help me ID this part so that I know what to ask for when I go the parts counter to get a new gasket? Also does anyone know if a bunch of STUFF (techincal term) will fall out once the cover is removed to replace the gasket?
THANKS for any advice,
Old Jul 6, 2005 | 06:28 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Front Axle Leak
Sounds like you're describing the CAD (central axle disconnect) housing. It's what connects the stub axle to the inner axle when you put your truck into 4 wheel drive. Nothing should fall out when you pull the cover off, but some more fluid might leak out. For that reason, now might be a good time to change the front differential/axle fluid Also, when putting the CAD unit back in, you have to make sure you line up the "fork" with the collar, so your 4wd will engage/dis-engange correctly. You'll see what I mean once you have it off.
And as a side note, you wouldn't really need to put a new gasket in there. I sealed mine with RTV when I changed my front axle seals. Works just as well
Old Jul 7, 2005 | 12:31 PM
dwhipper61's Avatar
dwhipper61
Thanks Rom for the info. I added a picture of the part in question just in case my description was a little off......
[IMG]local://upfiles/18108/5B00529F3B1E47B4B8772D07B0201CA1.jpg[/IMG]
Old Jul 8, 2005 | 02:51 AM
The Burning Rom
No problem...glad I could help. And yup...that's the CAD.
