Outer Axle/Stub Shaft
Old May 14, 2011 | 07:58 PM
mark77's Avatar
mark77
Default Outer Axle/Stub Shaft
The other night coming home from work the right side bearing decided to go out with no warning. I got a hub, and U Joints but the outer shaft/stub shaft ears are bent in just enough so I can't get the clip in the joints. Would I be able to bend this back so I can get the clips in or am I looking on buying a new part again?
Thanks!
Old May 14, 2011 | 09:52 PM
1998ram5.9's Avatar
1998ram5.9
you can bend them back. Allthough the right way is to replace it, you can bend it back. iv done it on an axle shaft and a drive shaft and they have held up fine.
Old May 14, 2011 | 10:46 PM
mark77's Avatar
mark77
Thanks for the reply. I only need it to work for a few weeks until I can get the new part in. What steps did you take to re bending it?
