I need help with CCD error on overhead display
Old May 19, 2011 | 04:44 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default I need help with CCD error on overhead display
I have a 2001 that had been butchered by the previous owner. The wiring system has so many cuts, splices and dead ends(no kidding, there was an 8-gauge cable with a bare end left connected to the battery, jammed behind the ABS controller!!!).... Anyway, I have been re-splicing, and trying to heal some of the damage. One of the things attempted was the Overhead Console upgrade. I overtook the project and got it working.... Somewhat. When I first turn the key on, it does the little segment test, the a second or two later I get the "CCD" message. I have tried running jumpers from other pur/blk and wht/blk pairs, to no avail. My only real clue is on my other truck, which has a functioning overhead console computer, when I unplug the ambient temperature sensor, I get a reading of -40 degrees, but on this one I get a reading of 248 degrees until I get the CCD message, which leads me to believe there is a short in the temp sensor circuit. But I can't seem to find those nifty little wire harness to sheet metal anchors, and the harness is difficult to get to for error checking. Any thoughts? Thanks!!
Old May 19, 2011 | 07:33 PM
ShelbyGT550's Avatar
ShelbyGT550
Was the console added after or was it factory?
Old May 19, 2011 | 09:04 PM
johnnyrocket5363
No; this is of my doing. The previous owner had attempted it, and had the computer, but assumed the plugs were the same and thus, at purchase, I had no map lights. I bought the harness from a junkyard, spliced it together, and installed it as I replaced the cracked dash. Now, I have my map lights, and power to the computer, and when I do the little test of holing down both buttons it passes, yet after about three seconds of turning on the ignition, the unit displays "CCD". The only real reading I can retrieve before the error is that I have around 71 miles to empty on a full tank (My Lord, I hope not!!) and an outside temp of 248 degrees...
Old May 19, 2011 | 09:08 PM
ShelbyGT550
did you run the ccd bus wires to the ccd bus line? there is a + and -
Old May 19, 2011 | 09:59 PM
johnnyrocket5363
Do you mean the purple/black and white/black twisted pair? I wired them straight, color to color....
Old May 20, 2011 | 07:35 AM
johnnyrocket5363
Do you know where the ambient temperature sensor module/driver is? I could check for a short much easier if I knew where the send went. I have a solid 5 volts to the sensor, and a slight continuity from the send to the ground.... Plus, I failed to mention earlier that the truck has the highline body controller... Thanks!
Old May 20, 2011 | 10:30 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
did you get the temp. sensor that lurks in front of the grille, under the hood?
Old May 20, 2011 | 06:54 PM
aim4squirrels's Avatar
aim4squirrels
+1 on the 2001 it will literally go up in the air over your head when you lift the hood. Turn around and look up.
Old May 20, 2011 | 11:00 PM
johnnyrocket5363
Yeah, I swiped that from a local junkyard. The funny thing is that on my 99, if I unplug the temp sensor and turn on the key, the reading is -40 degrees. On my 2001, if I do the same thing, the reading is 248 degrees, sensor plugged in or not.
Old May 20, 2011 | 11:01 PM
johnnyrocket5363
I have spare computers lying around, and I tried them with the same result. I plugged in the one from my 1999 as well, to no avail....
