P1757, P1762 error
Old Jul 7, 2005 | 12:23 AM
tcb2332's Avatar
tcb2332
Default P1757, P1762 error
My engine light came on and I have a P1757, and a P1762 error. This has to do with the gov. pressure being too low or too high. I changed the gov. solenoid in the transmission but I still have the error. Anyone know what I should try next? Any help will be greatly appreciated.
Thanks Todd
Old Jul 8, 2005 | 04:55 PM
steve05ram360's Avatar
steve05ram360
Default RE: P1757, P1762 error
there is supposed to be a pressure sensor in the tranny to monitor the tranny fluid pressure... you might try swapping that out. I had a problem with my tranny back in May and had 2 sensors swapped... one for the TC lockup and the other for line pressure. my problem went away. no codes were given from the PCM.
Old Aug 6, 2005 | 01:53 AM
Two60s98's Avatar
Two60s98
Steve -
Today, I drove down to Denver, and lost Drive again on the way back (see my post 'Another Tranny Failure - Maybe'). The Engine light came on too. I pulled a P1757 code. Tell me more about the sensors. Are they internal?
Old Aug 6, 2005 | 01:56 AM
Two60s98's Avatar
Two60s98
ORIGINAL: tcb2332
Thanks Todd
Todd, where is this govenor solenoid, so I can swap mine.
